TUF Gaming TF120 ARGB Fan - Triple Fan Kit with ARGB Controller
Warranty
Warranty 2 year manufacturer warranty
  • Class-leading airflow, and low noise levels.
  • Advanced fluid dynamic bearing provides up to 250,000 hours of operation.
  • PWM control: ultra-wide RPM range allows optimal cooling for all types of workloads.
  • Anti-vibration pads reduce fan noise by damping rattling and vibration.
  • A double-layer LED array produces deeper color saturation and more lighting effects than conventional RGB fans.
  • A bundled ARGB hub connects up to four fans and features onboard lighting control and Aura Sync support.
  • Available in both black and white editions to suit a variety of PC builds.
Product Name:
TUF GAMING TF120 ARGB 3IN1
Part Number:
90DA0030-B08030
Delivery Most orders ship out within 24 hours
Pickup A click away from your pick
Warranty
Key features
Tech Specs
Shopping FAQ
Fan Size
120 x 120 x 25 mm
Fan Bearing
Advanced FDB
Fan Speed
1900 rpm (+/-10%)
Fan Airflow
76 CFM
Fan Pressure
2.5 mm H2O
Fan Noise Level
29 dB(A)
Fan Input Power
2,88W
Fan Operating Voltage
5V-13.2V
Fan Starting Voltage
5V
Fan Input Current
0.24A
AURA Sync
AURA Sync
Product Dimension
120 (L) x 120 (W) x 25 (H)
Product Net Weight
139g
Fan Size
120 x 120 x 25 mm
Fan Bearing
Advanced FDB
Fan Speed
1900 rpm (+/-10%)
Fan Airflow
76 CFM
Fan Pressure
2.5 mm H2O
Fan Noise Level
29 dB(A)
Fan Input Power
2,88W
5V-13.2V
5V
Fan Input Current
0.24A
AURA Sync
AURA Sync
Product Dimension
Product Net Weight
139g
