TUF Gaming ARGB PWM Fan Hub
Free Shipping & Returns Conditions apply. See Shopping FAQs for more details
Get help buying You can email, chat, or call us any time
Safe and secure payment Your data is encrypted for your protection
Warranty 2 year manufacturer warranty
  • Connect up to six case fans
  • PWM fan and RGB connection for seamless syncing cooling and lighting effects
  • Visible power and operation indicators for easy status checking
  • Simple magnetic mounting for easy attachment to the metal surface of the case
  • Dual SATA power connectors for stable input under full load
  • Two safety fuses for overcurrent protection
Product Name:
TUF GAMING ARGB PWM FAN HUB
Part Number:
90DA00C0-B08000
Notify me
Out of stock
Delivery Most orders ship out within 24 hours
Pickup A click away from your pick
Key features
Tech Specs
Shopping FAQ
Fan Connector
6 Ports x 4 pin PWM
Fan Rated Voltage
12V
Fan Safety Current
2A (1 port) / total 9A (6 ports)
RGB Connector
6 Ports x 3 pin ARGB
RGB Rated Voltage
5V
RGB Safety Current
2A (1 port)/Total 9A (6 ports)
Power Connector
2 x SATA Power
Power Safety Current
2 SATA Connector Power Input
12V -> 9A (Max.)
5V -> 9A (Max.)
Dimension
115 x 69 x 17.7 mm
Weight
81.5 g
Fan Connector
6 Ports x 4 pin PWM
Fan Rated Voltage
12V
Fan Safety Current
RGB Connector
RGB Rated Voltage
5V
RGB Safety Current
Power Connector
2 x SATA Power
12V -> 9A (Max.)
5V -> 9A (Max.)
Dimension
115 x 69 x 17.7 mm
Weight
81.5 g
